Td sensor initialize issue
  • mdfurqan2012
    • 194
    Dear all,
    Today i replace developer in mp9002sp because of print/copy quality problem after replacing developer i want to intialize td sensor first i enter lot no. Then i do intialization by sp2801 but as i press execute complete message appear without any delay normally td sensor initialization takes 1min.
    I replace complete developer unit from other machine with developer but same issue occurs then i did all memory clear by sp5801 but issue not resolved, i check last developer was made only 26000 copies/prints and we replace that for mainting copy/print quality.
    Kindly guide me.
    Thanks in advance.
  • davel
    • Oct 2011
    • 1107
    Re: Td sensor initialize issue
    replace all PM parts with genuine Ricoh parts and start again, do not forget to re-input all the SP from birth certificate that you memory cleared.
    NEVER CLEAR ALL MEMORY!!!
    • vga_man
      • 78
      Clear develoer PM counter first
      • mdfurqan2012
        • 194
        When i did memory clear sp5801 all counter becomes reset. After that i input lot no. Again and again try to intialize td sensor when i press execute complete message appear. Issue not resolve.
        • Coptech
          worker drone
          • 460
          lot number must be 7 digits
            • 37533
            No, when you did SP 5801-001 you cleared settings not counters. You introduced the potential for a lot more problems than you corrected.
            • kannuki2
              • Feb 2012
              • 398
              The developer lot number does not matter on this model. Just make up any numbers (1234567). There is a tech pub on toner dusting and light copy for low usage. Indeed I agreed with SlimSlob about a memory clear. In my 10 years experience, I did one memory clear with the birth certificate in front of me.
              • Mark Bbb
                • Jun 2012
                • 1662
                I used to do this also, not putting in the correct value...
                I have noticed premature QA problems in 2 cases and since i put in the correct value, there were no problems anymore of this kind.
                So, better be ware!
                • keithxxiii
                  Just a tech
                  • Nov 2014
                  • 469
                  Aye! Cut the crap
                    • 37533
                    Developer lot number is for tracking purpose only. If you notice premature failure of developer on multiple units, you can report the lot number to Ricoh. If multiple people report problems with the same lot number Ricoh will QC that lot and if they determine it to be defective they might issue a refund.
                    • usta
                      • Oct 2013
                      • 44
                      What fault did you get when you got 26,000 copies?
                      Why did you feel the need to make a tds adjustment?
                      Did the machine make light color copies?
                      Was the machine doing toner dusting?
