Af2060 SC342
  • Butrus
    • Jan 2012
    • 115
    Af2060 SC342
    Hi,
    this machine doesnt feed toner by itself(light copies).It does it with forced tonner supply.
    When I execute TD sensor initial setting ,SC342 ocures
    Changed the TD sensor and its the same.
    Then I replaced the whole developer unit(used) from another machine and everything works OK...but have to return that unit...yust for check...
    Whats wrong with dev. unit from this machine?
    Thanx!
  • davel
    • Oct 2011
    • 1104
    Re: Af2060 SC342
    Clean everything, replace all parts that are near life, replace developer then initialise TD sensor.
      • 37490
      Re: Af2060 SC342
      Replace the TD sensor. Clean the ID sensor.
      • Butrus
        • Jan 2012
        • 115
        Re: Af2060 SC342
        @slimslob
        I already did that...
        @davel
        So you think changing developer would help?
        thanx
        • davel
          • Oct 2011
          • 1104
          Re: Af2060 SC342
          Dev initialization should only be done with new dev.
