MP8001 light image
  • aktasson
    • Feb 2017
    • 201
    MP8001 light image
    Hi there!
    our customer complained about a too light (light image) print out from pc and from copying.
    Does anyone have a tip on what could be the problem? 300k maintenance has already been done at 804k pages. The machine is now at 810207. The procedure with dev lot no and dev init successfully executed.
    After toner forced supply the black comes back. Checking SP2201-004 240V ok, SP2967-001 0 ok and SP3902-008 at 130 ok.
    • 37532
    Re: MP8001 light image
    Dirty ID sensor. If PCU components have gone past the recommended PM count, replace them.
    • mikadonovan
      • May 2008
      • 2931
      Make sure the ozone filters at the rear and the one just upstream from the fuser are clean. I've had similar issues on this model, and filter replacement was the fix. Also, if the smc numbers are correct, you had better install a new transfer belt and blade. More than 800k is a lot.
      NEVER ASSUME ANYTHING
      • tufbnme
        • 493
        Did you clean the mag roller when you changed the developer? Drum? Corona?
        • aktasson
          • Feb 2017
          • 201
          The filters ozone filter, development filter, filter toner and the dust filter where replaced by me during maintenance. The filters are components of the 300k maintenance kit. But i will check and replace on the next visit the tr belt. During the maintenance I had disassembled it to clean all the potential rollers.
          • aktasson
            • Feb 2017
            • 201
            I cleaned it as always during maintenance with a blower brush and SP3001-002 . I removed today at visit the drum unit and checked + cleaned again. The sensor was clean and no dust/soilung was around. I also think about to replace the tr belt and drum if the problem persists and the customer calls back again.
            As a temporary solution i have initialized the dev SP 2801 with good toner level condition after forced toner supply. The values of the Vref, Vt and Vsg seems to be ok.
            • francisco
              • Nov 2009
              • 168
              Replace the OPC drum.
              • vargue
                • Oct 2011
                • 404
                first detect that bottle is running well in exact time. and hopper is throwing toner well.open machine and see what happend. may be toner is moistured.and paper also moistured.make free run....i hope that helps
                • BEBEDELFUTURO
                  • Jul 2017
                  • 34
                  You checked the developer filter
