@Remote ID2 issues
  • Itanic
    • Dec 2014
    • 59
    @Remote ID2 issues
    Hi all,,
    We're a small company and only just started to get machines on @Remote a few months back. All our sites are pretty small with a maximum of 10 machines at most.
    Of course 1 or 2 machines have failed to go onto @Remote because of a bad or missing ID2. So....we have no R/C Gates and really don't have a need for them.
    @Remote support says to correct this you'll need an R/C gate and connect into the same network as the machine and rewrite the ID2 this way.
    Have tried all the fixes offered 5816-209 5570-3 and -1. On one machine @remote was disabled in security but it then rewrote an odd number still into 5811-3..
    As said all our machines are embedded,, if there is no other way and we have to buy an old R/C gate to get round this so be it....
    So.....Does anyone know if there's a way to rewrite the ID2 via the NVRam? like through a hex editor or something? or will we have to bite the bullet and get hold of an R/C Gate? Cheers
    • 37620
    Re: @Remote ID2 issues
    ID2 is normally rewritten by the @Remote server during registration. Check SP 5816-174. If it is too low, a timeout might occur. SP 5816-209 can be used to clear the embedded installation so you can start again.
    NVram data can be exported to a SD card through SP mode. The file could then be edited with a hex editor. The problem is where in the file is the encrypted data you need to change and what do you changed it to.
    • Itanic
      • Dec 2014
      • 59
      Thanks Slimslob. I just thought that you guys who have been using @Remote for almost 10 years might have had an easy way of resetting the ID2 other than use an R/C gate, as we've only been using using @Remote for literally 5 minutes in comparison.
      • zed255
        How'd ya manage that?
        • 1024
        As far as I know you need to use an appliance to do the ID2 re-write, never seen any other method.
        Those of us handling @Remote issues usually carry an old appliance for the purpose, mine is an RC Gate A.
        Might be something to consider getting as a 'service tool' the branch / dealership can share as needed.
        • mavetherave311
          • Oct 2012
          • 11
          the only other way is sp5870 3 and then 1
          • zed255
            • 1024
            That is only for the common certificate. It has no effect on clearing or resetting the ID2 code in my experience.
              • 37620
              A bad or missing common certificate will give the same error code in SP5816-208 as a bad or missing ID2.
              • zed255
                • 1024
                Slim, he already knows the ID2 is trashed and is asking how to fix it. Someone suggested re-initializing and re-writing the Common Certificate to correct the issue, which it will not.
                  • 37620
                  Sinnce he was not very specific as to when in the process that he got the error or the exact error number he got I can only assume that either SP 5816-202 or SP5816-206 failed with a Confirm Result or Register Result code of 8: Other error (See SP5-816-208 for detail). The error in SP 5816-208 was either "-12004 Attempted to install with invalid certification, ID2, and without input the machine number" or "-12009 Mismatched between ID2 in NR-RAM and ID2 in the individual certification". Both cases n=can be caused by a corrupted or missing common certificate. In fact, if ID2 contains five asterisks (*****) in stead of five spaces, the asterisks indicates a bad common certificate.
                  In any case what does it hurt to do as mavetherave311 says, clear the @Remote installation and start over. It might work and if it does it is a lot faster and less expensive than trying to get an RC gate.
