Scan for MP C2500
  • Dumus
    • Feb 2010
    • 79
    Scan for MP C2500
    Boys,
    if there is newer firmware for MP C2500 scan options. I have 1.25 (B238 5604J) ?
    Thanks in advance.
  • barratec
    • Jun 2008
    • 162
    Re: Scan for MP C2500
    Hi,
    I think it's the latest one.
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      Old model.
      Last update apart from the fax option was way back in 2011.
        • 37357
        What are you trying to scan to, folder or email? Had you provided this at the get-go we night have already given you some work arounds.
        • Dumus
          • Feb 2010
          • 79
          Not ,
          I have color problems. Reads the white background with ARDF as reddish, and
          with glass is greyish.
          Some recommendations ?
          P.S. Normal, cleaned optic.
          • sandmanmac
            • 3979
            Originally posted by Dumus
            Not ,
            That's got nothing to do with F/W.
            This is in all likelihood caused by you, or someone else doing memory clear (SP801-001).
            Hopefully the "non-default setting" sheet is inside the front cover. If so, start inputting the default settings to get it back.
            • Dumus
              • Feb 2010
              • 79
              Sandmanmac,
              I did it only once in my life (5-801), and never again (15 years ago). So this is not the cause of these scanning events.
              • Brianneoe
                • May 2015
                • 318
                I had a wacky issue like that a few years back. Run a full SMC report and look at the settings in the 4s. Check for values that are out of range of the others and then adjust it back towards the other color range. I had two or three SP settings that were way out of whack that caused a heavy green brown tint to the pages.
