How the Reset The Counter ?
  • RebelPhoenix
    • Oct 2008
    • 138
    Hello My Dear Friends,
    I need the digital counter reset Ricoh AF-1013 and 1015. But I don't want to change nvram. I need a different solution.
  • totoro
    • 568
    If you're talking about the meter, that is illegal and highly unethical.
    Totoro
    • RebelPhoenix
      • Oct 2008
      • 138
      Yes, This is illegal information but I need So I don't ask the " How is the up the counter ? " Only I says and need for example my copier 28k I want to do this count 0.
      • nmfaxman
        • 1702
        run 720,000 copies and it will zero out.
        • E Winter
          You will need a prommer to do this. Upload the NV Ram data to a card, write the whole NV Ram with FF data, reinstall, programm serial number and maybe marketing area within factory mode and restore the NV Ram backup. Very easy if you have the necessary hardware but also very useless and risky on a second hand machine. I wouldn't recommend it.
          • JustManuals
            • Jan 2006
            • 9838
            Call Ricoh. They'll point you in the right direction.
            • RebelPhoenix
              • Oct 2008
              • 138
              Call Ricoh . Yes Dear Jan. I need a eprom programmer.
