Ricoh MP C6503 add staples
  • tibbs
    • Aug 2008
    • 225
    Good day folks, I have a customer with a ricoh mp c6503 that's giving the message staples, the thing is the staple cartridge is loaded with staples.
    I have taken the cartridge out and inspected it, it has no jammed staples, and the unit does not appeared to be jammed. It seem to be moving freely.
    I am a bit puzzled as to what seem to be the problem. Its a booklet staple finisher SR4120/SR4130 D3CG/D3CH.
    Any help is much appreciated.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MP C6503 add staples
    Have you tried a complete, brand new cartridge? They do wear out after a while. Also could be the customer has been a bit forceful fitting a cartridge and damaged the staple head.
    Hit it.
    • tibbs
      • Aug 2008
      • 225
      Thanks bro, I have already tried a new cartridge, same problem add staples.
        • 37377
        Did you install a new Staple Set Cartridge order code 415009 or only a new Staple Refill Cartridge order code 514010. If it wasn't the Staple Set Cartridge, order one and replace it.
        There are 2 micro switches in the staple head that determine if staples are present and ready to use. One is activated by a lever in the staple head when the staples senses when first staple is in the staple position. the other is activated by a small black lever in the bottom of the Set Cartridge that detects the trail edge of the last staple sheet leaving the refill cartridge.
        • HitMan
          • Aug 2015
          • 170
          Could be the harness that runs from the stapler to the main board. 03 models seem to wear out the cable over time. Do a continuity check with a multi meter on each wire or you might be able to see the break
          • semi
            • Sep 2008
            • 193
            Its a booklet staple finisher-Have you checked the 2 booklet staple cartridges??????????
