animation firmware
  • slot
    • 341
    animation firmware
    This is such a silly question I have upgraded the firmware on loads of copiers but I wanted to see how to upgrade the animation firmware on a mpc3003 with non sop opps panel.
    I have downloaded the firmware and put it in the romdate folder etc but the copier wont show it in the list to upgrade so I check out the service manual to see if it needs to be uploaded in a special way the problem is I cant find any info relating to it any one pointe me in the right direction
    • 37357
    Re: animation firmware
    If it does not show on the list of firmware, then it is not present on the machine. I believe that it is only present if you have an App install that requires it. Installs with the App.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Animation has not been updated since the model's initial release, so shouldn't need updating. Anyway, it is updated the usual way.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        I don't mean to be rude, but please use some punctuation in your sentences.
        Run on sentences can be downright painful to read.
        Thanks.
