Ricoh Aficio MP 6500 web motor
  • Vladika
    • Dec 2016
    • 40
    Hello, I changed the web motor, the machine works normally untill I have changed the new cleaning web, I have tested the motor in output check mode, the motor doesn't work. What can cause that problem?
    • 36833
    Re: Ricoh Aficio MP 6500 web motor
    Unlike other motors, the web motor does not run constant in output check. It only pulses on momentarily. You have to mark the first gear and check if it has moved.
    • davel
      • Oct 2011
      • 1077
      was it a new motor?
      • Vladika
        • Dec 2016
        • 40
        Thank you. I know that it does not work constantly , because I tried it when I replaced it, but today when I tried it did not hear it pulsing. I do not know if it's possible to get a short circuit somewhere and burn it or the engine just is not good? Because this is a new engine, I spent just one cleaning web with it, but it will not run the other one. I tried the mechanism when I removed the engine, there is no stuck.
        • Vladika
          • Dec 2016
          • 40
          Originally posted by davel
          was it a new motor?
          Yes, it was
          • TonerMunkeh
            Professional Moron
            • 3865
            Take the web unit off, leave it connected, cheat the front door and run the web motor in output mode. That'll tell you if it's turning. If not, it'll be the BICU board.
            Hit it.
            • Mark Bbb
              • Jun 2012
              • 1662
              When the web holder ass'y is old, it can happen that the web film gets blocked.
              In that case I replace all the one way gears, and off it goes again...
              • imaginemoko
                unTrusted Tech
                • Jan 2008
                • 289
                does this new motor tested in working machine? if its working then perhaps your bcu/iob is defective.
                fix the customer first then fix the machine... its simple and makes life more easy.
                • Vladika
                  • Dec 2016
                  • 40
                  I did not try it, but I tried something else. From the other machine I took the unit which the motor was running and put it in this machine. Nothing happens, the motor will not start. Three days ago, I marked with a graphite pencil cleaning web, and this morning when I came, people worked on the machine, the machine was warmed up, I pulled out cleaning web unit I looked and saw that the line did not move. Thank you very much, I have to try this motor in working machine
                  • Zoran
                    • 44
                    Moras promeniti Q23 na bicu ploci proverene zamene su bcx54 i bcp54
                      in english?
                        • 36833
                        in english?
                        Try using https://translate.google.com/
                        • Zoran
                          • 44
                          You have to change Q23 to the bicu boards of the tested replacements are bcx54 and bcp54
                          • Vladika
                            • Dec 2016
                            • 40
                              why? hell I refuse to even press 3 for english on a phone call
