Ricoh mp7502 Temperature drops
  • liontech
    • Dec 2010
    • 12
    Hi guysI have a strange problem with ricoh mp7502When printing a job, the temperature drops a lot, starts at normal temperature (190) and falls to 160 !.It does not throw sc code in the screen, but in history it appears sc991.I changed everything, fuser rollers, lamps, drum, developer, boards, I use original and generic toner and the temperature drops tooObviously, it does not blow the toner.any ideas?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh mp7502 Temperature drops
    SC991 is generic software error. Most of the time it can be cured by updating the firmware, however, sometimes it is a fault in the BCU or RAM.
    If you check the values of SP7-403 it should tell you a bit more about the code, Ricoh will need this information if you contact them.
    Does the SC appear at the same time that the temp drops? Does it drop immediately or during printing?
    • liontech
      • Dec 2010
      • 12
      Thanks for the replyThe code appears when the temperature drops.From the fifth copy begins to decrease the temperature
      • Batman1976
        • Jun 2016
        • 88
        Hi,
        Just a thought............ There was a similar fault related to temperture issues on the previous models (MP6002). The bracket of the thermistor was modifyed within the fuser unit. Might be worth a quick check of the thermistors and the position of the securing bracket. Also an SP mode was changed
        Set Sp 1105-002 (Fuser temperture adjustment normal time) to 180 sec (defualt 190)
        Also check following sp's are all at defualt
        1105-001
        1105-003~14
        1107-001~24
        hope that helps
        • Mark Bbb
          • Jun 2012
          • 1662
          Are you sure this temperature drop is abnormal?
          Have you checked with another mp7502?
          Like Ruben said, sc991 doesn't have to relate to this issue.
          If it was a fuser issue, would it than not provoke sc5** fuser error codes?
          • liontech
            • Dec 2010
            • 12
            Originally posted by Batman1976
            Hi,
            1105-001
            1105-003~14
            1107-001~24
            hope that helps
            Yes, the bracket is correct, I checked a bulletin that talked about that and the temperatures are well configured.Thank you very much for the reply
            • liontech
              • Dec 2010
              • 12
              I think so. I did tests on similar machines and the temperature drops from 190 to 184, 185.The machine is installed at 2000m above sea level, but I do not think that influences because there are many machines in that place and they do not present flaws.thanks for your help
              • Cipher
                It's not easy being green
                • May 2006
                • 1309
                • Test the fusing lamps with a multi-meter and check they are all working.
                • Clean / replace the thermistors.
                The hot roller is only a thin teflon coated roller, so the paper as it passes though at 75ppm will remove some of that heat.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  if there is no toner on your finger when rubbing over the paper, I don't think there is a problem.
                  You must know that - due to environment issues - fusing of toner is much more efficient than on earlier models.
                  (and I think that is good.)
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    it could be that one (of the 2) is not working..., precisely
                    • Batman1976
                      • Jun 2016
                      • 88
                      Have you fitted the new type Cleaning Webb to stop the build up of paper dust?
                      • kannuki2
                        • Feb 2012
                        • 398
                        I wonder if someone was playing with the Sp mode. Perhaps changed to 150
                        • liontech
                          • Dec 2010
                          • 12
                          Guys, the problem was low input voltage, I had to buy voltage stabilizer.Thank you very much for your comments.
                          Sorry for the delay in responding.
