MP C3503 RFID
  • ABS tect
    • Sep 2013
    • 511
    MP C3503 RFID
    I had a 3503 come in with a RFID device for users to scan their cars to operate the machine. I would like to take this off. I unplugged the USB of the device from the print card, reformatted the HDD, Did 5801-10 and -11. Took off user authentication management, set system settings to default. Yet it still loads the Java software and requires you to scan your card to use the machine. There are no Sd cards in the print card however.
    What do I need to clear in SP mode?
    • 36833
    Re: MP C3503 RFID
    You don't. You uninstall the App. Usually in User Tools - Extended Features or through WIM. Prior to doing that do the following to disable the App:
    Enter User Tools
    Press System Settings
    Press Administrator Tools
    Press Next
    If Enhanced External Charge Unit Management button exists, select it
    Unselect All Copier, Printer, and Document Server buttons
    Press Exit
    Press Exit
    This will allow functions to work without a card
    Enter User Tools
    Press Function Priority
    Select the machine function that you want as default
    Press OK
    Press Exit
    Press Exit
    Check the following settings and return them to default:
    SP 5113-001
    SP 5113-002
    This will turn off the Enhanced External Charge Unit Management button exists
    • ABS tect
      • Sep 2013
      • 511
      Re: MP C3503 RFID
      Enter User Tools
      Press Next
      Press Exit
      Press Exit
      Enter User Tools
      Press OK
      Press Exit
      Press Exit
      SP 5113-001
      SP 5113-002
      You're the bomb man... That did it.. Thanks so much.
