MP 8000 Error SC990
+ More Options
Posts
  • fbkhan3
    • May 2012
    • 421
    MP 8000 Error SC990
    I have MP 8000 throwing SC990.
    Originally had SC220, Replaced Polygon Mirror Motor and BCU(D054-5122)with old (EPROM) which fixed the Laser error.
    Now it continuously throws
    SC990,
    Details
    LINE : 1141
    VAL: 995
    FILE: ENG: device.c
    1:Firmware flashed.
    D0545127E/Engine
    B2475101Z/System/Copy
    2: HDD Replaced
    3: Maintenance Kits are All New
    4: PM counters 0
    went through goose Guide and done/checked all related things .
    Kindly suggest if i need to replace controller or is there anything else which can be a fix.
    Regard's
  • trc
    • Jan 2007
    • 95
    • fbkhan3
      • May 2012
      • 421
      Re: MP 8000 Error SC990
      Laser is from another working machine, and SC history is all 990 and 991.
      Regard's
      • TonerMunkeh
        Professional Moron
        • 3865
        Another Martini of the same age, i.e. 6000/7000 or another range, i.e. 6001?
        Hit it.
        • fbkhan3
          • May 2012
          • 421
          Thank you very much TonerMunkeh
          Laser unit is from 7000,brand new mirror motor and BCU ordered from Ricoh.
          Regard's
          • kannuki2
            • Feb 2012
            • 398
            Sc 220 is caused by two things.
            1. Check the condition of IPU BCU Harness (B247 5451) if damaged replace it
            2. The laser diode board B2471859 is defective.
            Check for bent pin on the laser connectors.
