Ricoh MP C305 - Printer saying ''PLEASE WAIT'' and not doing anything else
  • florian.dita
    • Dec 2015
    • 1
    Hi all,
    I have got an Ricoh MP C305SP (no HDD, no FAX) wich starts normally but the printer module is staying in ''PLEASE WAIT'' status and can't do anything on it.
    What I have done:
    1. Checked everything working in Output Mode
    2. Checked fusing unit temperature ok
    3. Tried different fuser
    4. Firmware update
    5. Memory all clear
    6. Changed the controller and the BICU board
    My next step is the control panel and PSU, hopefully one of those is gonna solve it but I'm not very confident. This machine drove me crazy, working on it for 2 weeks and no luck.
    Any idea would be much apreciated.
  • lawchatkui
    • Aug 2017
    • 79
    Re: Ricoh MP C305 - Printer saying ''PLEASE WAIT'' and not doing anything else
    Normally "please wait" problem can solved by formatting the HDD, but yours without HDD, quite strange
    Sent from my Mi 4i using Tapatalk
    • francisco
      • Nov 2009
      • 168
      Originally posted by florian.dita
      Hi all,
      What I have done:
      4. Firmware update
      5. Memory all clear
      one of the 2 (512Mb) memory in the controler is missing or faulty
        • 37491
        Check the memory installed. Since the C305 does not require HDD in order to print, its memory requirement is higher. If it does not have 1 GB or the memory is corrupted, the print function cannot initialize.
        • jtancrede@successos.com
          • Jun 2013
          • 7
          Here's what Ricoh says:
          SYMPTOM:
          CAUSE:
          The LCDC firmware has a bug.
          SOLUTION:
          Install the following firmware versions or later as a set. .
          Firmware Version Program No.
          LCDC 1.16 D1171491G
          System/Copy 1.06 D1175421F
          • Polarbear
            • Feb 2012
            • 1070
            Hi all,
            What I have done:
            4. Firmware update
            5. Memory all clear
            5. Memory all clear <--------never do this again! It will never fix anything - it will just create more problems!
            Press the GREEN button!!
