Mpc3501 poor quality print out
  • lawchatkui
    • Aug 2017
    • 79
    Hi pro, is it this poor print out caused by toner? Thanks in advance
    Sent from my Mi 4i using Tapatalk
    • 37532
    Re: Mpc3501 poor quality print out
    If you were a qualified Ricoh tech, you would know the answer to that.
    • vga_man
      • 78
      always use ORIGINAL OEM TONER.
      replace cartridges and empty pumps pro
      • lawchatkui
        • Aug 2017
        • 79
        Pro, the problem is the customer print out 5 copies, only one copy with this type of problem.
        • lawchatkui
          • Aug 2017
          • 79
          & customer very less to use color copying can be a cause too? Toner will get hardened?
          • andy227
            • Jan 2013
            • 219
            Totally agree. Also I noticed, on the opening page of the forum, thread listings, you have EIGHT new thread/questions. That has to be a record !
            SEF or LEF ? (I suspect LEF) Do you know about individual pcu test pattern printout, to find which one of your dev units is giving problem ?
