help
  • BEBEDELFUTURO
    • Jul 2017
    • 34
    help
    Hello, how's it going? Good morning.
    I have a problem with a computer ricoh 6001 the computer is stopped I was walking but the error started, the cleaning was done to the load crown, some values ​​were made of it but the error persisted, opt with test with modulo and corono Of a 7001 computer but followed the problem. I do not know what to do with someone who solved this problem.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: help
    If I'm reading this right, the web's run out?
    Hit it.
    • BEBEDELFUTURO
      • Jul 2017
      • 34
      Re: help
      could you be more specific
        • 37532
        Re: help
        • tufbnme
          • 493
          Re: help
          What????
          • BEBEDELFUTURO
            • Jul 2017
            • 34
            Re: help
            Ricoh 6001 sc 300
            The module and the load crown were replaced and sc persists
              • 37532
              Re: help
              What module and what the hell do you mean by load crown?
              As for the SC 300, it is Goose's Guide. Search it on this site and download it.
              • rapidocument
                Multibrands Tech
                • Jul 2012
                • 381
                Re: help
                Pagina en espanol para fotocopiadoras:
                Fotocopiadoras - Foro de Reparación - YoReparo
                (copier tech page in spanish)
                My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Re: help
                  If I'm not translating his post correctly (at all) I think he's got an SC300 after changing both the corona unit and power pack. Try changing the entire PCU with the 7001 and see if the problem goes away.
                  Hit it.
                  • tufbnme
                    • 493
                    Re: help
                    Originally posted by tufbnme
                    What????
                    WHAT??????
                    • andy227
                      • Jan 2013
                      • 219
                      Re: help
                      why didn't he so say in the first place ? sc300 is the same in spanish as it is in english.
                      when you changed the power pack, did you change the receptacle also ? It is possible this will also cause the sc300. Coronna - Receptacle - Power pack.
                      Cambia el receptacle tambien, no solo la corona y el power pack.
                      • BEBEDELFUTURO
                        • Jul 2017
                        • 34
                        Re: help
                        ricoh frame sc 300. was cleaned the crown of charge and the module but the error perdisistio. I tried with a full module unit but the error persists
                        • andy227
                          • Jan 2013
                          • 219
                          Re: help
                          This is too much hard work. Are we even on the same page ?
