MP2851 scan to usb drive
  • ahjie0608
    • Apr 2017
    • 3
    [Misc] MP2851 scan to usb drive
    Hello guys,
    I would like to know whether Ricoh MP2851 can scan to USB drive?
    I found there is a USB port at the controller board,but when i insert my
    USB drive,nothing appear in machine panel.
  • Polarbear
    • Feb 2012
    • 1070
    Re: MP2851 scan to usb drive
    Originally posted by ahjie0608
    Hello guys,
    If i remember correctly you can make it work, but there is a setting in SP mode that needs to be activated.
    Press the GREEN button!!
    • ahjie0608
      • Apr 2017
      • 3
      Thank a lot for your advice,i am checking the setting in SP mode but i am not sure which is the correct SP code.
      • Elmo
        • Feb 2010
        • 541
        I Used To Live To Fix Things Now i Fix Things To Live
        • Polarbear
          • Feb 2012
          • 1070
          Elmo
          That "kit" was just a convenience feature, bringing the slot to the front on the machine - besides giving access to an sd card slot as well.
          If the setting is on the ports directly on the controller accept memory devices. It is just more of a schelp to plug/unplug it on the side of the machine.
            • 36743
            That should be Printer SP mode. The kit is not needed. Just use a USB extension cable and connect it to the USB slot that the kit would connect to.
