Ricoh machines xx04sp and new xx04exsp models
  • Nasim
    • Aug 2017
    • 8
    Having trouble with many machines that have safecom, they are having a restart problem, you get a
    technical problem on the screen and have to restart your machine.
    The log logged SC899, some one have the same problem?
    Thank you for all the answers
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Ricoh machines xx04sp and new xx04exsp models
    Solutions are a bit of a nightmare.
    SC899 is a general service code that means a software error has occurred.
    The code is not very helpful as there is little indication to the root cause, e.g it might be Safecom, but could just as easily be a print job or some other function causing the problem.
    Many fixes for SC899 will be via firmware updates and server and client app software updates issued from the software solutions vendor.
    You need to troubleshoot and try and re-create the sequence of events leading up to the triggering of the service code.
    Then log a support call with Ricoh when you have gathered all the information you can on the problem.
    • Brianneoe
      • May 2015
      • 322
      Your 899 code issue may have nothing to do with this print release program but more to do with bad print jobs from the internet. Check your firmware versions first. I had a installation of a new MP 6055 that would not stop printing PS error pages from Chrome until I installed the pcl5 driver.
      • mikadonovan
        • May 2008
        • 2931
        This is true. Printing some HTML documents will cause this code. Unplug the network cable and reboot the machine. If this clears it, have IT clear the queue in the server, or clear the PC queue if its peer to peer structure. Firmware and Java needs to be current.
        NEVER ASSUME ANYTHING
        • Brianneoe
          • May 2015
          • 322
          Another quick fix if nobody can pin down where the bad job is coming from is to turn on "user auth" per user codes- reboot the machine with it on the network, wait 5 minutes and then turn off user auth. That will spool out all the waiting jobs and get everyone working again
          • TonerMunkeh
            Professional Moron
            • 3865
            Also check the heap and stack settings. They should be set to 75% of the maximum memory.
            Hit it.
            • Nasim
              • Aug 2017
              • 8
              Re: Solved Ricoh machines xx04sp and new xx04exsp models
              solved, it was firmware bug with java.
              • Zaxxon
                • 608
                safecom are not supported on the ex models, or am I wrong?
                Please start you post with brand, model, problem.
                • Nasim
                  • Aug 2017
                  • 8
                  The ex models support safecom.
