Ricoh MP 1600 dark copies in the am
  • jper34
    • Sep 2011
    • 225
    Hi Folks,
    I've a customer that is getting real dark, background copies usually if copier hasn't been used for awhile..I did replace drum/developer unit with new, but didn't help. I checked the brass bias tab on inside rear frame where drum/dev slided into. Any ideas..I know,it's an old copier,, but I'm trying to by them time, till new bidget is approved....Thanks !!
    Jaime
    I.C.S.
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: Ricoh MP 1600 dark copies in the am
    Originally posted by jper34
    Hi Folks,
    Jaime
    I.C.S.
    How long is "hasn't been used for a while?" Days, weeks, months? There is an SP called developer mixing, I believe it is right next to the SP for developer initialization. Running that might help.
    • jper34
      • Sep 2011
      • 225
      1st thing in the morning, to 3 hrs., after they may run 20 copies, background will clear up..
        do they turn it off at night? on bootup they will run thru a quick calibration ....
          • 37533
          It could be from moisture build up during the night. It could be in the PCU or affecting contact of the drum ground plate to the drum shaft in the main drive.
          • jper34
            • Sep 2011
            • 225
            Yeah...I did replace the drum unit and developer unit, no change...I did check developer bias tab, just bent it out a little to be sure it's making good contact..I'm at a loss..thought the drum and developer unit would be the culprit..now I'm wondering if an hvt unit or main pcb...? any suggestions surely welcomed..
            • jper34
              • Sep 2011
              • 225
              oh..I did run developer initial....copies were fine when I left, next day, today, cust. says it's the same darkness / background..
                • 37533
                Please reread my previous reply. I was not talking about the bias. I was talking about the drum shaft ground. It is on the main drive unit. You have to take the back off to get at it.
                • LNorris
                  • Sep 2008
                  • 645
                  Is it next to a window? sunlight?
                  • jper34
                    • Sep 2011
                    • 225
                    the copier is not near a window...but the drum ground does sound pausible..I'm not sure where the drum is grounded, I see on the rear drive unit, am I looking for a ground strap attatched to the main drive unit?
                      • 37533
                      Faulty drum ground is a major cause of dark background. It is a small metal contact plate on the main drive unit housing and has a lead connected that goes to the HVPS.
                      • jper34
                        • Sep 2011
                        • 225
                        Thanks..! I'll go Monday, and let you what I find..thanks for the help !!
