Ricoh Aficio MP1600 SC543 But fuser is OK
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
  • COPIERMAN
    • Jun 2009
    • 559
    Re: Ricoh Aficio MP1600 SC543 But fuser is OK
    try this leave rt side door open then reset code turn off and back on with rt side door open. Should say door is open if it clear code properly. now cheat interlock switches and see if fuser heats up and says ready.
    SC Code Reset
    5810 1
    Resets all level-A service call conditions, such as fusing errors. If the reset is
    successful, the display shows "Completed." If the reset fails, an error message
    shows.
    • mikadonovan
      • May 2008
      • 2931
      IF the thermistors and thermostats check OK, you may be looking at a power supply replacement.
      NEVER ASSUME ANYTHING
        • 37560
        You could have a wire harness problem.
