MP C3001 Light PCU'S
  • ABS tect
    • Sep 2013
    • 511
    MP C3001 where all 4 colors were super light, I would to a forced toner supply to bring them back up to looking good but eventually they would go back to being light. So i switched all 4 PCU's and was good for a while but now they are all super light again. And they all seem to go at the same time. Is there maybe a setting that tells it how long to supply toner for? I know when you are doing a forced toner supply you can change the toner supply time, but is there a way to do that for normal operation? Because i feel like maybe it is just not getting enough toner to it. Toner pumps and hoses seem fine because when i do a forced toner supply i can tell it worked. Any thoughts?
    Re: MP C3001 Light PCU'S
    did you initialize the new PCUs in service mode?
      • 37375
      Did you clean the ID sensor assembly? Did you run ACC? Did you clean the laser shield glasses? Is the PTR making full contact with the ITB?
      • davel
        • Oct 2011
        • 1095
        Did you fit 4 new PCU's, what are the dev counts, do not fiddle with toner settings.
        • ABS tect
          • Sep 2013
          • 511
          They were not brand new pcu's that i swapped them out with.
          I ran ACC, cleaned the laser shield glass with the cleaning stick in the front cover, cleaned ID sensor assembly...did not check the PTR though, i will check that, clean everything again and let yall know thanks
