Lanier LDO16 doc feed
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    This machine has only 3000 copies on it and the doc feed will pull the second and third pages together and sometimes the last two pages. I replaced the seperation roller and cleaned the rest., No change. Should I have changed the whole assembly?
  • lvsb
    • Aug 2008
    • 70
    Replace the spring plate under the sep roller assembly. The part number is B8722251.
    Please see TSB#7R for further details.
    • E Winter
      Yep - install the modified spring plate or bend the existing spring plate very slightly to reduce it's spring-force. In both cases I recommend to apply some grease at the DF's bottom plate (the point where the spring plate touches it - you will see).
      You also should install the additional mylar's because without the DF likes to damage the original's leading edge without them.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Thanks for the positive feedback, it is what I was looking for, I knew it would be something that I had not encountered, but would sound logical when I heard it.
