RICOH Aficio MP C3500 Error Code SC 443
  • ISLEVIBES
    • Mar 2014
    • 20
    [Error Code] RICOH Aficio MP C3500 Error Code SC 443
    So was replacing the toner pumps from bad toner problem.
    I left a toner pump wire hanging and when i replace the transfer unit
    the connection caught the wire and cut both blue wires.
    and I got ERROR CODE SC443
    So i completed the pump replacements and secured my wires properly.
    I turned the copier on but SC443 came up again on the screen
    I clean the id sensor by sliding the door
    and the error code is still there.
    I removed the id sensors and cleaned them
    still no luck. I swapped out transfer unit same thing.
    all the round silver spinning motors on the back spin on copier start up.
    please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    How do I reset error code SC 443? and do you think that's the problem.
