ricoh 1075 cover is open as shown message
  • waleed
    • Jul 2017
    • 9
    ricoh 1075 cover is open as shown message but all the doors are closed
  • COPIERMAN
    • Jun 2009
    • 559
    Re: ricoh 1075 cover is open as shown message
    check interlock switches see if they are good. some of them can be check using input check in service mode.
    • waleed
      • Jul 2017
      • 9
      what are the correct values
      now values are 10111111
      • COPIERMAN
        • Jun 2009
        • 559
        zero for close and a 1 if switch is open. Are you a tech should have all ready known this.
        • davel
          • Oct 2011
          • 1076
          they are switches, either on or off.
          • COPIERMAN
            • Jun 2009
            • 559
            if you are using input check in service mode will show either a 0 or 1 state. doesn't say on or off you have to know what position switch is in. if it doesn't change state then you know switch could be bad or wiring problem or the logic board is bad. then that's where you get a volt meter and start checking things out.
              • 36812
              It is in the service manual. Section 5.6.1 copier input checks.
              • jmotz
                • Jul 2011
                • 30
                Could be blown fuse FU109
                • waleed
                  • Jul 2017
                  • 9
                  It\s fuse 105 thanks
                  • waleed
                    • Jul 2017
                    • 9
                    Is the COPY CONNECTOR board and kits in ricoh2075 the same as dsm 675
                      • 36812
                      This information can be found in the legend section of both the service manual and parts catalog.
