Fusing troubles
    Re: Fusing troubles
    what does the repetitive defect ruler in the manual tell you it is?
      • 37514
      #17
      Re: Fusing troubles
      From the service manual:
      119-mm intervals: Drum
      101-mm intervals: Fusing unit (Pressure roller)
      107-mm intervals: Fusing unit (Heating roller)
      • tufbnme
        • 493
        #18
        Re: Fusing troubles
        Rebuild the fuser. I messed with this same issue once and talked myself out of rebuilding because the sleeve looked good and it was withing service life. Once I replace the sleeve assembly and LFR, the issue disappeared. These fuser don't seem to go to life and will wear quicker when running any thick paper.
        • Voltageza
          • Jun 2017
          • 71
          #19
          Re: Fusing troubles
          Hi
          Thanks for this but the image repeat interval is at 95mm
          • Voltageza
            • Jun 2017
            • 71
            #20
            Re: Fusing troubles
            Hi
            I have replaced the complete fuser unit.
