Default PDF in Scan (Cheetah Panel) - simple question
  • tonnerboy
    • May 2011
    • 212
    Hi all.
    I need to put in to default the Multipage PDF in the Cheetah Scan funtion. I can make it localy on the device but I have several locations and it would be simple for me to do it remotly. I can not find the option in WIM...
    Can same one help me on that?
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Default PDF in Scan (Cheetah Panel) - simple question
    On the G2 panels there is Remote Panel Operation from the WIM.
    More information here: Download Camel-SL Technical Reference.zip
    *You need the latest firmware versions installed.
    But there should be default scan options in the WIM for the classic and the simple scanner modes in any case.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Originally posted by tonnerboy
      Hi all.
      If you have the classic scanner enabled, you can set the multipage PDF default by just setting the scan settings to Full Colour, and press Program button on the bottom left.
      • tonnerboy
        • May 2011
        • 212
        Thanks to all for your help.
        By request of the customer I did not enabled the classic Scan.
        I know that I can put by default the classic scaner, but like I said they are using the cheetah scan version
