DSM651 ARDF Problem
  • rsyarcia
    Hair Straightener Tech
    • 711
    DSM651 ARDF Problem
    When the machine is in the standby mode, Our customer wants to wake up the copier by opening the ARDF but there was no reaction . I checked already the sensors especially the DF position sensor using the input check all are working ok. Any Idea on how to enable this. Tnx again
    Nobody is perfect..
  • Jomama46
    • 2900
    Strange. It should also wake if you touch the LCD or put a doc into the feeder. So either of those wake it?
    I dont see any settings in UT or SP for this feature.
    sigpic
    A+; Network +; PDI+
    • iMind
      Vacuum Cleaning Expert
      • Mar 2008
      • 1116
      See if you can find something useful:
      User Tools (System Settings) Timer Setting
      Auto Off Timer
      The machine turns off automatically to conserve energy after a specified
      amount of time has passed following job completion. This function is called
      “Auto Off”.
      The machine status after Auto Off operation is called “Off mode” or “Sleep
      mode”. For Auto Off Timer, specify the time to elapse before the Auto Off
      function is activated.
      Note
      Default setting: 1 minutes
      ❒ When in “Off mode” or “Sleep mode”, the machine can be ready for use
      within 25 seconds.
      ❒ Auto Off Timer function will not operate in the following cases.
      • When a warning message is displayed
      • When the service call message is displayed
      • When the paper is jammed
      • When the cover is open
      • When “Adding Toner” message is displayed
      • When the toner is being replenished
      • When the User Tools/Counter screen is displayed
      • When fixed warm-up is in progress
      • When the printer or other functions are operating
      • When operations have been suspended during printing
      • When the Data In indicator is on or blinking
      • When the sample print or confidential print screen is displayed
      ❒ The time can be set from 1 minute to 240 minutes using the number keys.
      Energy Saver Timer
      Set the amount of time the machine waits before switching to Low Power
      mode after copying has finished or the last operation is performed.
      Note
      Default setting: 15 minutes
      Settings You Can Change with User Tools
      Panel Off Timer
      Set the amount of time the machine waits before switching the panel off after
      Note
      ❒ The warm up time for making a copy from standby mode is 0 seconds.
      ❒ The interval time can be set from 10 seconds to 240 minutes using the
      number keys.
      ❖ System Auto Reset Timer
      The System Reset setting automatically switches to the screen of the function
      set in Function Priority. This happens if no operations are performed or when
      an interrupted job is cleared. This setting sets the system reset interval.
      “Function Priority”
      Note
      ❒ Default setting: 60 seconds
      ❒ The time can be set from 10 to 999 seconds in one second increments using
      the number keys.
      ❖ Copier/Document Server Auto Reset Timer (Copier/Document Server)
      Specifies the time to elapse before copier and Document Server functions are reset.
      Note
      ❒ If “OFF” is selected, the machine will not automatically switch to the user
      code entry screen, and you will not be able to limit who uses the machine.
      the number keys.
      ❖ Scanner Auto Reset Timer (Scanner)
      Specifies the time to elapse before the scanner function is reset.
      Note
      the number keys.
      • rsyarcia
        • 711
        hi
        MR jomama, if you touch the LCD or put a doc into the feeder still no reaction. Mr. Imind thank you so much!!this is a big help.
        Nobody is perfect..
        • cobiray
          Passing Duplication Xpert
          • Mar 2008
          • 1199
          I've not seen this, and I don't know if it will help, but you might want to update the firmware.
          I think Paul might be on to something with the timer. Are you sure the machine is in "sleep" mode or is it completely off? If you have to press the power switch on the control panel to wake it up, it's not asleep it is off. Try adjusting your timer settings in that case.
          • iMind
            • Mar 2008
            • 1116
            Thats my thought too.
            • rsyarcia
              • 711
              Hello sir the machine is in sleep mode.
              Nobody is perfect..
              • FRIDGEMAGNET
                • Aug 2007
                • 377
                There is also Night Mode if the printer/scanner is fitted.
                6.14.5 NIGHT MODE
                This is used instead of auto off mode when an optional scanner/printer unit is
                installed.
                There are two types of night mode: Night Stand-by Mode and Night Mode. The difference between night stand-by mode and night mode is the machine’s condition when the machine enters auto off mode.
                Entering night stand-by and night modes
                The machine enters the night stand-by mode and night modes when one of the following is done.
                • The operation switch is pressed to turn the power off
                • The auto off timer runs out (the operation switch is then turned off, but the main
                power switch stays on)
                What happens in night stand-by and night modes
                When the machine enters either of these modes, the fusing lamp and operation switch turn off, and only the main power LED is lit.
                Night stand-by mode
                The system +5V and +24 V are supplied to all components.
                Night mode
                The system +5V supply is also turned off. However, +5VE (+5V for energy saver
                mode) is still activated. When the machine detects a signal from the PC, the
                machine goes back to night stand-by mode and the system +5V and +24V supplies
                are activated. Then the machine receives the incoming message and prints it.
                Returning to stand-by mode
                The machine returns to stand-by mode when the operation switch is pressed. The recovery time is about 45 s.
                • Jomama46
                  • 2900
                  This will be an interesting resolution.
                  sigpic
                  A+; Network +; PDI+
                  • rsyarcia
                    • 711
                    hi
                    Mr. Cobiray, Mr. Imind, Thnx. Mr. Cobiray was right.the machine auto off timer was set to 15 mins. the same with the energy saver mode(15mins.) that's why when you put a paper on the ardf,touch the screen or move the adrf up the machine has no reaction(coz the machine is already in auto off after 15 mins). I just made auto off timer to 120 mins then set the energy saver mode to 2 mins. and that's it. the machine should be in the energy saver mode to activate it when you touch the screen or ardf.
                    Thank you Guys!!!!!!!!!!!
                    Nobody is perfect..
                    • Jomama46
                      • 2900
                      Glad you got it sorted out. Thanks for getting back to us.
                      sigpic
                      A+; Network +; PDI+
                      • rsyarcia
                        • 711
                        hi
                        Of course I have to thank you all!!!
                        Nobody is perfect..
