MP C4501 not waking up
  • Staggan
    • Jan 2017
    • 54
    Hello
    I have an MP C4501 that is refusing to wake up after going to sleep...
    First thing I did was update firmware, which made no difference.
    Then I replaced the control panel, checked connections to control panel and BCU etc.. but still no joy.
    Anyone have any suggestions before I try BCU ?
    Could it be power supply perhaps?
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: MP C4501 not waking up
    Assuming you have updated the PowerSaving Sys to F.19, try disabling STR (Suspend-to-RAM), cycle the power off / on and give it a test.
    SP 5191-001 to 0
    • Staggan
      • Jan 2017
      • 54
      Hello Cipher
      Thanks for the suggestion.. that seems to have resolved it.
      What is the reasoning behind this causing a problem?
      • Cipher
        • May 2006
        • 1309
        STR has been known to be a little bit temperamental on some Ricoh controllers depending on the peripheral configuration.
        Sometimes a firmware update can fix it, but the workaround is just to disable the feature which is enabled by default.
        • Staggan
          • Jan 2017
          • 54
          Thanks for the update, machine now seems fine.
          I'll add this to our list of issues we've not seen for future reference.
          Thanks again.
