MP C4501 Skew when copying but fine when printing
  • Staggan
    • Jan 2017
    • 54
    Hello
    I have an MP C4501 which is skewing copies from the scanner glass but when printing it is fine.
    I've checked the manual and cannot find anything overly helpful and wondered if anyone had seen this before.
    The skew is the same from ADF and scanner glass, but no skew from printing either counters or from a PC, therefore I assume it is an optics issue...
    • 37514
    Re: MP C4501 Skew when copying but fine when printing
    Users have been leaning on the control panel and have warped the scanner unit.
    • Staggan
      • Jan 2017
      • 54
      Any suggestions on being able to resolve it?
      • oyedokunmj
        • Sep 2016
        • 7
        It is scanner problem
        Sent from my Infinix X510 using Tapatalk
          • 37514
          Level the scanner section to the rest of the machine.
          • keithxxiii
            Just a tech
            • Nov 2014
            • 469
            agree with slim, i have faced this issue on an MPC3003, it turned out the scanner unit is slightly deformed. This usually happens when the users do a copy and lean on the MFP.
            Aye! Cut the crap
            • Polarbear
              • Feb 2012
              • 1070
              +1
              To check if the scanner frame is skew, lift the df, and lightly tap on the copy glass. It should product a dull sound. If you can hear a pinging sound (like the glass is loose) then the scanner frame is skew.
              Also check that all the scanner mirrors are seated properly, as a skew scanner mirror can also cause this.
              Press the GREEN button!!
              • Staggan
                • Jan 2017
                • 54
                I was afraid the scanner may be skewed...
                No ping from the glass, all seems to be seated properly.. and mirrors all seem to be in place...
                Is there any adjustment to fix this sort of issue other than try to brute force the scanner back into shape?
                • Polarbear
                  • Feb 2012
                  • 1070
                  You can check if the scanner assembly is true to the frame. There are 4 holes in the scanner frame that can be used. The scanner rails should line up with these (one hole on each end of the scanner rails) so that when you put pins (or the right size screwdrivers) through the frame holes, they should just slide in - one uses the same procedure when replacing the scanner cables.
                  Hope this makes sense.
                  • Staggan
                    • Jan 2017
                    • 54
                    Not sure I understand which holes...
                    Can you direct me in the manual or with a picture.. ? Thanks
                    I would have thought there would be a way to rotate the scanned image slightly in service or in settings... but seem unable to find anything to do that...
                    • Elmo
                      • Feb 2010
                      • 541
                      Try lifting the front left hand corner of the scanner up ( looking at the machine from the front place both hands on the LH corner of the scanner and lift upwards)
                      if this improves or makes things worse you will have a start point to work from
                      I Used To Live To Fix Things Now i Fix Things To Live
                      • Staggan
                        • Jan 2017
                        • 54
                        I've looked at comparable images again... and I don't think it is actually skewing the image
                        If I take a meter reading, it is fine, if I take a copy of that the bottom of the leading edge, for about 5mm is skewing, but NOT further up the document...
                        It basically is a perfect copy, but the line across the bottom of the meter reading curves up for about 5mm at the leading edge...
                        Any thoughts??
                        • TonerMunkeh
                          Professional Moron
                          • 3865
                          Yes, grab the front left hand side of the scanner and pull it up. You'll get a pop when the scanner returns to position.
                          Hit it.
                          • sturmtrooper
                            Copier Combobulator
                            • May 2016
                            • 587
                            Any thoughts??
                            Does it do this when both using the doc feeder and the scan glass? If it doesn't do it when using ADF maybe the scanner carriage isn't moving properly.
                            • Staggan
                              • Jan 2017
                              • 54
                              Hello
                              Yes, it was doing it on both....
                              It seems with a little brute force and some minor twiddling with the carriage cable fixings I now have it straight...
                              Thanks for all the help....
