sc 990
  • lary leon14
    • Oct 2008
    • 44
    sc 990
    What about this sc 990 in a lot of copiers as 1075/700 aficio?
    How it resolved it?
    Who let the donkey out?
  • Jomama46
    • 2900
    Flash the firmware, replace the HDD, eliminate arcing from the developer, xfer units, spray the carpet with anti-static solution.
    Can also be caused by and often is: old drum, dying developer.
    sigpic
    A+; Network +; PDI+
    • DIONISIS
      • Oct 2008
      • 17
      How it resolved it?
      1.CLEAN THE CONTROLLER
      2.USE THE HDD ABOUT 2/3 CAPACITY OF D.SERVER
      3.CLEAN THE MACHINE IF IS DIRTY(PCU-ID-POTENTIAL)
      DIO-masterprint
      • Jomama46
        • 2900
        #2 I havent heard before, will you please expand on that?
        sigpic
        A+; Network +; PDI+
        • Shadow1
          • Sep 2008
          • 1642
          Also caused by bad power - This time of year the A/C gets shut down, and the heaters come on. Some places it's pure electric heat, and the extra load causes problems. Sometimes with Oil heaters the ignitors put a lot of noize back on the line. Every shop needs a power monitor to check stuff like this - Bad grounds and high neutral voltage don't show up under all loading conditions, and line noize can't be read with a standard tech meter at all. We use a powertronics PQR-52 - it's about $600.00, but it has saved us thousands
          73 DE W5SSJ
          • Polo-022
            • Sep 2007
            • 486
            What about the first one? How do you clean controllers dionisis?
            • darachen
              • Jun 2008
              • 13
              In service manual : SC 990 Symptom
              Software performance error
              The software attempted to perform an unexpected operation
              Possible cause
              Software defective
              Internal parameter incorrect
              Insufficient working memory
              when this SC occurs, the file name, address, and data will be stored in NVRAM . This information can be checked by using SP7 - 403. Note above data and the situation in which this SC occurs. Then report the data and conditions to your technical control center.
              In life : Ask for answer in copytech still can not solve the problem
              • mpaunov
                SC 990 on Ricoh Aficio 990
                I just had that problem.
                I switch off and on the machine and everything was ok.
                About 15-20 mins after that electric insurer on electric network turn off electric power in that electric socket.
                So, as I read that electric power can be problem in one previous post, I think that in my case that was the problem.
                • lary leon14
                  • Oct 2008
                  • 44
                  Re: sc 990
                  drum was in my situation the problem,i changed it and everything is ok now.Thank you all of you for the advices.
                  • serviceman1
                    Re: sc 990
                    In most of the cases, the problem is the drum. If you look closely, you can see frayed edges.
                    • Eric1968
                      • 2458
                      Re: sc 990
                      This thread is from 2008!
                      What's really funny is that the original poster (lary leon14) posted the solution 6 years later!!
                      • Debs1964
                        • Oct 2010
                        • 1693
                        Re: sc 990
                        He obviously wanted to make sure it really worked before updating us lol
                        There are 10 types of people in this world, those who understand binary maths and those who don't
                        • Eric1968
                          • 2458
                          Re: sc 990
                          If the problem stays away for 6 years, you really can say that you solved it!
                            • 37533
                            Re: sc 990
                            Good thing he didn't need to update the firmware as both of these are the older PCMCIA card machines.
