MP 4055SP "Invalid Firmware is installed" message on boot up.
  • KapeKopyTek
    • Nov 2013
    • 284
    Brand new machine, right out of the box, first boot for the passwords, reboot, get "Invalid Firmware is installed. Correct Firmware: (MachineType:null)(Generation:null)(Destination:ge n). Installed Firmware: (MachineType:Office)(Generation:1)(Destination:gen ).". Called the hotline, they had me load previous version of System (v1.07), still didn't work, they recommended changing out the NV-Ram and Eeprom. I will keep you posted.
    And yes, I'm still semi-retired after having both knees replaced, 3 days a week in the office preflighting new machines, refurbing older machines, parts, etc. Not a bad gig!
    • 37621
    Re: MP 4055SP "Invalid Firmware is installed" message on boot up.
    Out of the box failure, I would contact Ricoh to replace under warranty.
    • KapeKopyTek
      • Nov 2013
      • 284
      Installed new NVRam and EEPROM, rebooted, now I get the invalid firmware message in Japanese(?), set SP5-131-001 to 1, no change. Ricoh Express told me to contact my TSM, which I am. To be continued........ On the bright side (I guess), SP5-811-004 shows the machine didn't lose it's serial number......
      • DRichard
        • May 2008
        • 482
        Reflash/update SOP firmware (on the OP Panel)
        "Enjoy every sandwich."
        -- Warren Zevon
        • KapeKopyTek
          • Nov 2013
          • 284
          RESOLVED
          Yes, the error is caused by corruption of the program files in the Op Panel Control Chip, and the fix is covered in TSB 28 for the C4504. It involves accessing the recovery mode, wiping a partition, and rebooting. No need to mess with NVRam and Eeprom.
          • Cipher
            It's not easy being green
            • May 2006
            • 1309
            RD242046
            If you looking for it on Tier2.
