paper feed cut
  • ped2017
    • Jul 2025
    paper feed cut
    hi we have a mp cw 2200 wide format and we just wanted to feed out a piece of blank paper ...how do we do that ?
  • mikadonovan
    • May 2008
    • 2931
    Re: paper feed cut
    Roll the paper back onto the roll, then reload the paper into the machine. It will giver you a cut sheet around 12". Or, just take a pair of scissors and cut the size you need directly off the roll. Just FYI, you have to be patient with this ink machine, as in loading paper and replacing ink carts will take a considerably longer process time than a machine that uses toner.
    NEVER ASSUME ANYTHING
