pro 906ex
  • T911
    • Jun 2007
    • 628
    pro 906ex
    this one keeps going light, i can force toner and it will come back but it goes light after a big run and stays light. ideas appreciated.
    Re: pro 906ex
    what have you done if anything?
    can you post pics of the issue?
    OEM or 3rd party toners?
    how many pages are on it?
    • totoro
      • 568
      Re: pro 906ex
      what are your values for vsg and vsp?
      Totoro
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1257
        Re: pro 906ex
        If all the needed maintenance has been done and that happens on that model you could try:
        set it to turn on the ID sensor every 30 copies.
        SP2507-01 to 1 and SP2507-02 to 30
        That's assuming the machine doesn't need a PM and the developer is not way past due to be replaced
        Also could be the start of a failing toner supply motor (hopper) or toner pump
