aficio 1075
  • ahmadkha95
    • Sep 2017
    • 6
    aficio 1075
    i'm have aficio 1075 and using it as printer but it is very slow when print pdf files because it using the network card ..
    can be add usb card or convert 1075 to be faster as printer ??
  • davel
    • Oct 2011
    • 1108
    Re: aficio 1075
    check that windows has not installed it with class driver and wsd port. Network should be quicker than USB.
      • 37560
      Re: aficio 1075
      Also make sure that Windows did not install it using the WSD port. I have seen new models take as much as 30 minutes to print a 1 page pdf when using the WSD port.
      USB 2.0 and IEEE1394 options were original available for this dinosaur but good luck finding them now.
      • ahmadkha95
        • Sep 2017
        • 6
        Re: aficio 1075
        i'm using Tcp/Ip port but when print pdf the size of file is large and i'm show the buffering is very slow .
        • ahmadkha95
          • Sep 2017
          • 6
          Re: aficio 1075
          the port using is TCP/IP but the main proplem the buffering when print pdf is very slow .
          The main proplem is slow with buffer .
            • 37560
            Re: aficio 1075
            The main problem is that the machine is ancient. If you want speed, buy something new. Ricoh terminated assured parts availability for this model six year ago.
            • ahmadkha95
              • Sep 2017
              • 6
              Re: aficio 1075
              Thank you for your interest and accept your answer .. this the best solution
