aficio 1045 Abnormal sc 990
  • alamen
    • Aug 2025
    I have a problem code sc 990 on Aficio 1045.
    The machine does not go in ready.
    if you unplug hard disk works without duplex (and I know that)
    but after that I try to detach and attach hard disk some times everything worked well. already changed drum and blade
    and maked Adjustments sensor id .
    I don't changed developer it works for 140.000
  • Shadow1
    • Sep 2008
    • 1642
    Replace the Hard Drive. They sit inside the controller box and bake - I've seen the HDD fail 5 to 10 times more in this series machines than in all the other machines I work on combined.
    The problem was so bad I submitted a design to Ricoh to modify the outside face plate to include a CPU fan that you can get from any computer shop for about $3.00 including the connector that splices into the HDD power.They could have made the whole thing available for less than 10 bucks. I got no reply - go figure.
    73 DE W5SSJ
    • Jimbo1
      • Mar 2008
      • 845
      No, see, you implied they had a design flaw which never happens. Particularly on that series.
      Everything has been gold since the Aficio 350. You know that.
      "Some days you get the bear, some days the bear gets you."
      Cdr. William Riker
      • ZeusGT
        • 271
        HA! Ricoh responds to one of their techs...I think not!
        Seems like Ricoh is more so anti employee than anything else.....
        I agree though with the design....
        CompTia A+ Certified
        CompTia Net+ Certified
        CompTia Server+ Certified
        CompTia Project+ Certified
        OP Scanshare Certified
        • Shadow1
          • Sep 2008
          • 1642
          Companies used to require their engineers to work as techs for a few years before allowing them to design anything... Made so much sense they obviously had to stop doing it.
          Count the shadows!
          73 DE W5SSJ
          • ZeusGT
            • 271
            just like many other things that have happened at Ricoh... yuk
            • Jimbo1
              • Mar 2008
              • 845
              Just only the one shadow now but I left the library long ago.
              Cdr. William Riker
              • Shadow1
                • Sep 2008
                • 1642
                I'm ghosting...
                73 DE W5SSJ
                • alamen
                  On the main board there is a "Reset" button :
                  what happens if active It ?
                  • Shadow1
                    • Sep 2008
                    • 1642
                    Which "main board"? If it's the controller (where the HDD is mounted) it's gonna be kinda hard to hit while it's installed in the machine and powered up where it has a chance to do anything.
                    In any case there are no references to it in the service file, so likely nothing would happen. Maybe a CPU reset, but that's kinda like turning the power off/on. May also be that smoke pours out of every orifice just before the whole thing explodes and leaves a massive crater. Push it and let's see - if we don't hear back from you, we'll know not to try it ourselves
                    73 DE W5SSJ
                    • alamen
                      Yes, is tha main board in wich is mounted the hard disk
                      Is possible to activate it before removing a little carter near it
                      but i don't know that can happen when my finger click on IT
                      I Hope that someone knows that
                      I think that IT don't resolve the "990" Problem
                      "Push it and let's see - if we don't hear back from you, we'll know not to try it ourselves" ( You're a little "Bastard Inside" )
                      PS:Sorry for my english I'M From Italy
                      OK shadow1 if you come in italy I 'll ask you to push It for me
                      • Shadow1
                        • Sep 2008
                        • 1642
                        Your English is better than my Italian...
                        I'd be happy to push the button for you if you could provide an airline ticket, ground transportation, food, and lodging... and maybe a tour guide
                        73 DE W5SSJ
                        • alamen
                          and Why Not...........Some Italian Girls Too....
                          • Lagonda
                            • Aug 2008
                            • 1649
                            I must be getting old, I spent more time looking at the bike!
                            • Shadow1
                              • Sep 2008
                              • 1642
                              What Bike?
                              73 DE W5SSJ
