I know this copier is ooooooooooooooooooold yet I'm a service provider that needs every customer he has; that being said I only have 2 of these copiers under a maintenance contract that was in place when I took over the business in 2006 which included toner. I know the toner is no longer available from the sources I use to get it from. I did find a bottle of Group 610/620 toner for model #'s 5500/6645/6655/6665/7661 that I only have enough for maybe two more refills one for each copier. I financially can't afford to replace these machines at this time. Does anyone know where I could find toner that will work in these copiers. I've experimented with other toners & developers with no luck.
Thanks!!!
Thanks!!!
