MP 4054 question on toner sensor
  • dacjkhadley
    • Mar 2013
    • 19
    I have a MP 4054 that has been overtoning to the point that the prints feel like braille (exaggerating a little bit). When I go to sp 3702-001 and hit execute it comes up FAIL. I tried this on a MP 3554 and same result. According to the manual I should be getting a voltage reading from the toner sensor without engaging the engine. Is this correct? This is a new sensor thinking that was the cause. Also followed Ricoh's suggestion of doing the installation procedure after the dv unit was replaced. I am waiting to hear back from the client as she will let me know if the condition returns immediately. Could this possibly be a board problem?
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: MP 4054 question on toner sensor
    Assuming you mean 3074 ID Sens check :exe, which is what the 54 I have next to has it also fails on my machine which is brand new out of box.
