richo aficio 2027 printing problam
  • digital eye
    • May 2025
    hi guyse
    i just joioned here i have a richo aficio 2027 machine it was working as copier printer and scaner vry well
    suddenly network printer stop working. when i tried to reinstall the network print system shows the following messege
    The detected device is unknown type be sure that
    1 the device is properly configured
    2 the address on privious page is correct
    when i ping the ip address which is 192.168.1.110 printer reply is ok
    i cudnt understand wats the problem
    if any1 can help me out
  • rthonpm
    • Aug 2007
    • 2847
    More than likely with that IP address you're using a router set up to for DHCP. Something else has picked up that IP address and the copier is floating out there with a new one, or if it's set up for a static IP there's a conflict over that address.
    Set the machine up with an IP outside of the range that the DHCP agent of the router controls and then create a new printer port using that address. You'll be good to go after that...
    • Shadow1
      • Sep 2008
      • 1642
      That's only half the ping test - the other half is to turn the machine off or unplug the network cable and ping again. If you still get a reply you have a duplicate IP.
      73 DE W5SSJ
      • nmfaxman
        • 1702
        Unplug the machine or just turn it off.
        If you get a ping reply, another node is sharing the IP.
        I let the machine get a DHCP address then change it to a static address with the last octet 20 to 30 above.
        On a server network I will add 100 to the octet and tell the IT geek to exclude it from the range.
        • digital eye
          hello guys
          i unplug the network cable and ping the machine there is no reply from that address when plug the network cable i received the reply
          which means there is no duplication of IP address. i m uploading the image of the error if it could help to understand the problem
          • Peds
            Hi there
            @ that point (Standard - Generic Network Card) of the installation just click next, next, finish. Wait a while then another window will open and add your printer driver and set up your paper sizes before you send a test page.
            • Shadow1
              • Sep 2008
              • 1642
              Ricoh Type C network card
              73 DE W5SSJ
              • digital eye
                its still same guys driver instaltion is sucessfull but when i tried to print a test page after some time it shows an error that this document is fail to print
                • digital eye
                  please help me any idea any solution regrading network card please please
                  • Jomama46
                    • 2900
                    Make sure the sub net mask is the same as the one listed in the workstation you are pinging from. (ipconfig)
                    sigpic
                    A+; Network +; PDI+
                    • bonnie750
                      • 302
                      sounds like windows device manager has bombed out somehow. check device manager for red crosses or question marks against the device or ports.
                      uninstall EVERYTHING to do with the printer and restart the pc.
                      reinstall from a fresh dowmload from Ricoh and try the pcl 5 driver
