Printer Tray Selection Issue - Ricoh Aficio MP C3002
  • deco-pak_designer
    • Jul 2025
    Hi Guys,
    As in the title, when I try to print from the Mac to a Ricoh Aficio MP C3002 it defaults to Tray 3 and even when I change the tray in Media & Quality it still just goes to tray 3.
    I have tried resetting the print system and also removing printer drivers.
    I am using
    an iMac running Yosemite 10.10.5.
    Any help you guys can provide would be greatly appreciated.
    Many thanks,
    Sami
  • StephenB
    • Aug 2015
    • 243
    Re: Printer Tray Selection Issue - Ricoh Aficio MP C3002
    Originally posted by deco-pak_designer
    Hi Guys,
    I am using
    Many thanks,
    Sami
    Sami,
    Many times the default tray has to do with the print application defaults (not the printer - Ricoh in this case)
    What software ( word) or application (adobe reader) ? check their defaults
    • Horologydoc
      • Jun 2011
      • 61
      You could also try changing the preferences in CUPS. It's a Unix based spooler new Mac OS use. There are plenty of videos and instructions if you google it.
        • 37490
        Originally posted by StephenB
        Sami,
        Default tray setting on a Ricoh MFP only comes into play when there are two or more trays with the same size paper and the job is set to auto paper select.
