MP c7500 Developer Intake Fan SC 570
  • Timmytronic
    • Oct 2010
    • 249
    Hiya. I have a MP c7500 Developer Intake Fan SC 570 issue. I don’t normally do these machines now as moved onto newer machines.
    Can someone help help me with the location of the intake fan for the developers. On the 6502 series they are in the hopper but in the MP c7500 Manual it does not say and this machine is different. I assumed it’s one of the fans on the face plate. I have changed these so it seems not to be.
    Any advise be on the location of the fan and sc 570 that would be gratefully received.
    Thanks. Tim.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MP c7500 Developer Intake Fan SC 570
    There are 4 or 5 fans in the toner hopper, this code can sometimes be cause by the fan harness being pinched by the lugs on the faceplate. There was a modified board to fit to it to stop this happening also.
    Hit it.
    • Timmytronic
      • Oct 2010
      • 249
      Hiya. The thing is even with the hopper off it comes up with the code. Is the board inside the machine or on the hopper? Thanks for getting back.
      Tim.
      • TonerMunkeh
        Professional Moron
        • 3865
        Yeah, the 570 is usually caused by the hopper being off the machine but I've seen it with it on when the harnesses get nibbled. The modified board is on the hopper itself.
        Hit it.
        • Timmytronic
          • Oct 2010
          • 249
          Harness looks ok. I have just reset the hard drive and it worked again. Did copies etc. Switched the machine on and off and now back to sc570 so it must be a dodgy board. Frustrating as I slung a few hoppers away a while back.
          • TonerMunkeh
            Professional Moron
            • 3865
            The harnesses look fine, it's where they are pinched on the faceplate that causes the issue. Check on my-ricoh and see if you can find the RTB for the correct way to route them.
            Hit it.
            • Timmytronic
              • Oct 2010
              • 249
              Hiya. I have had a look at the wires and nothing is pinched so it must be the board on the hopper causing the issue. There was an update for the engine which I have done so that is my only choice.
              thanks for the advice.
              • Timmytronic
                • Oct 2010
                • 249
                Hi thought I would update on this query. I replaced the board in the Hopper and that seemed to solve it for a day then it came back. I then replaced the whole Toner hopper and still no joy. The customer was getting desperate so I have sorted them a MPC 8002 now so hopefully a nice welcome upgrade with clean reliability.
                Thanks for all the advice.
                Tim.
