MPC3003, ADF DF3090
  • GeorgeBest
    • Jul 2009
    • 520
    MPC3003, ADF DF3090
    HI,
    Still got problems with feeding originals on a DF3090.
    Seems that the feed roller B7892114 has changed, its thicker than before, notices this at a new MPC2004ex
    does anyone now of this modification?, and what's the new part number . . .?
    Thanks in advance
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: MPC3003, ADF DF3090
    Originally posted by GeorgeBest
    HI,
    Thanks in advance
    D6842114ROLLER:PAPER FEED BELT-DRIVE This is the part that sits on the drive shaft and drives the feed belt
    B3872113ROLLER - PAPER FEED BELT This is the part that sits behind the pickup roller and has ribs at the edges.
    Both out of the DF3090 parts manual. I don't think it's a modification, they just decided to use different parts in the doc feeder.
    The part number you listed goes in the DF3040 and 3050, at least according to precision roller.
    • guitar9199
      • Sep 2016
      • 1100
      • gemmajean
        We had the same issue, tech found a piece of plastic under the roller and belt that he removed and we have had no callback since..
