Hi guys,
having an issue with my MPC 305spf, turned the machine on and comes up with a red light, I check the status of the red light under the "check status" button, there is a problem with fax. i press the fax option and i get a "15-01" code. According to the service manual for faxes 15-01 indicates "POP3/IMAP4 Server Not Registered" solution: "At startup, the system detected that the IP address of the POP3/IMAP4 server has not been registered in the machine."
I have cycled the machine a few times, checked interface and fax settings, nothing seems to be out of the ordinary, I have updated machine to latest firmware and still no luck...
Any help would be appreciated.
