BK 5030 Fault code: Bk-159
  • shango215
    • Aug 2025
    [Error Code] BK 5030 Fault code: Bk-159
    Hi All, I seem to be stuck with a similar problem to the thread referring to a Bk-151 fault with the same machine. I'm wondering if it is the same some how. Plockmatic Bk 5030 with trimmer and bookfold unit set up as a stand alone. on powering up it initializes then goes to faultcode: BK-159 Faultinarea, power off and on. Picture just shows machine with exclamation mark inside triangle. Can anyone tell how to address this one and the service manual would be worth its weight in gold event though i'm more in the tin range? Thanks
    • 37538
    • shango215
      Re: BK 5030 Fault code: Bk-159
      Thanks All , it was in deed non communication, and everything is now working fine. I appreciate the clarity
