ricoh 1224c error sc560
  • bigcopy
    • Jun 2025
    how about this code mean?and how to resolve it.thank a lot.
  • FRIDGEMAGNET
    • Aug 2007
    • 377
    A fimware upgrade can fix this but I suspect you have an unstable mains supply, in which case the firmware will make no difference.
    • bigcopy
      Thanks a lot sir
      • MFPGUY
        • Oct 2008
        • 25
        I agree with your diagnostic I will also try using a good line conditioner after updating the firmware. A course the clients needs to purchase it. If you are able to isolate the problem this way then the client will have to hire and electrician to check line conditions.
        • Shadow1
          • Sep 2008
          • 1642
          I know it's getting close to Halloween since I keep seeing these monsters rise from their grave.
          73 DE W5SSJ
