Mpc6502 .sc442-00
  • jtymabel
    • Aug 2008
    • 164
    Mpc6502 .sc442-00
    Has anybody encounter this error before
    Sent from my SM-G955U using Tapatalk
  • MIKON
    • Jul 2015
    • 188
    Re: Mpc6502 .sc442-00
    I.T.B. Lift motor p/n D1361212
    • blee
      Technical Trainer
      • 54
      There is a bulletin on this. The worm gear on the tiny lift motor cracks and stops working. Change the lift motor. D1361212 Real pain in the rear getting to the motor too.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Here is the technical bulletin
        Regards Mark
        • peterxu256
          • Jul 2014
          • 110
          Thanks the bulletin, the photo taken recently from MPC8002, and motor 8 wires connector. the bulletin see the motor has 2 wires connector.
          want to know what's difference. Thanks
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            That bulletin is for the itb lift motor and there is only two wires on that motet it should be a worm gear motor.
            Regards Mark
            • peterxu256
              • Jul 2014
              • 110
              Failed to att@ch the photos. My motor just from the machine, have 8 wire connector, don't know why.
                • 37532
                You are looking at the wrong motor. The lift motor is not mounted on the ITB assembly. If you search the part number in the parts catalog you will find it is part of the main drive.
                • guitar9199
                  • Sep 2016
                  • 1100
                  +1 on this. I've had one go bad on me, and it was quite involved swapping the motor out. Don't skip ANY steps in the service manual... follow them closely. It'll be less painful.
                  • peterxu256
                    • Jul 2014
                    • 110
                    Resize the attachment of the motor photo. it is indeed mounted at rear side , Part # clearly says AX060460
                    • peterxu256
                      • Jul 2014
                      • 110
                      Hi Mga, see the resize photo, the motor has 8 wires is correct one or not AX060460 marked on the part 8 wire motor.jpg
                        • 37532
                        [ATTACH=CONFIG]42651[/ATTACH]
                        Wrong motor.
                        • peterxu256
                          • Jul 2014
                          • 110
                          Wrong motor.
                          Yes, It was indeed wrong motor. Feeling shameful. see the photo below that it was hard to be found since Part catalogue didn't indicate clearly, Problem exact same as that RTB Bulletin Thanks for all.
                            • 37532
                            [ATTACH=CONFIG]42684[/ATTACH]
                            I believe that the correct motor is not actually shown in your photo. From looking at the parts catalog, it is on the other side of the plate that those in the picture are mounted.
                            • MIKON
                              • Jul 2015
                              • 188
                              The tech pub thst mga posted should be all the information you need
