MPC5504 default setting for memory storage device
  • Debs1964
    • Oct 2010
    • 1693
    Hi guys, it's been a long time since I visited, so please accept my apologies.
    I have a customer with an MPC5504ex, and they want to set the default setting for printing from a memory storage device to black & white, does anyone know of a way to do this, I have searched with no joy.
    There are 10 types of people in this world, those who understand binary maths and those who don't
    • 37560
    Re: MPC5504 default setting for memory storage device
    Attached is from User Guide - Print - Using the Print/Scan(Memory Storage Device) Function Print-scan-memory-device.pdf
    In case the Print/Scan(Memory Storage Device) Function is not available and Printer (Classic) function Icon has been setup it is the same as for the previous models.
    • Debs1964
      • Oct 2010
      • 1693
      Attached is from User Guide - Print - Using the Print/Scan(Memory Storage Device) Function [ATTACH]38094[/ATTACH]
      Thanks Tim, but that just shows how to change the settings for a print job, not how to change the default settings. The print/scan from memory storage device app is installed.
        • 37560
        I would say use the Classic Printer function and see if you can set the defaults there.
        • Debs1964
          • Oct 2010
          • 1693
          I'll try that next time I go to one of these machines, but, if it's anything like the scanning apps, then you have to set the defaults individually for each app
            • 37560
            The Classic functions operate exact the same as on machines without the SOP. This includes setting defaults.
