External Authentication Error
  • roman2304
    • Oct 2013
    • 30
    [Error Code] External Authentication Error
  • sharpmind
    • Sep 2009
    • 478
    Re: External Authentication Error
    Turn off the user authentication.......USER TOOLS---ADMINISTRATOR TOOLS---USER AUTHENTICATION--OFF
      • 37529
      Sounds like it might been installed at a military base and had a CAC card device connected or in some other environment where an external device, such as a hecon counter, was required to use. Check SP settings SP 5401 Access Control and return all to Default. Check SP 5113-001 and -002. They should be set to 0.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        SP5846-046 and once completed reboot the machine.
        Upon reboot use the default blank password setting.
        Do this for Supervisor and Administrator 1.
        This has to be done via Factory mode only.
        • roman2304
          • Oct 2013
          • 30
          • incognegro
            • Feb 2013
            • 20
            It will work but you need to see what the error is before you can proceed.
            If you wait long enough the machine should pop up with an error message that you could use to diagnose the issue. It could take up to 15 minutes before the error pops up so be patient.
            • mikadonovan
              • May 2008
              • 2931
              Run a non-default data smc and see if you have an unusual setting enabled.
              NEVER ASSUME ANYTHING
                • 37529
                Originally posted by roman2304
                Slimslob: In SP-5401, the only option that was changed was SP-5401-001 to 3. I adjusted to the default value (0) and nothing happened.
                Thanks!!!
                Did you check SP 5113? 001 is for physical devices. 002 is for JAVA applications. If SP 5113-001 is or was set 5, MF Key Card, check SP 5114 and return it to 0.
