Mp2550 not fusing properly
  • wilbert.c
    • Apr 2014
    • 24
    [Misc] Mp2550 not fusing properly
    Mp2550 during copying the pressure roller and the hot roller just separate due to pressure roller bearing rings out of positions. the fusing frame is not broken . any help please ?
  • totoro
    • 568
    Re: Mp2550 not fusing properly
    The pressure roll is pretty much held in place with the spring on the inner side of the bearing and presses against the metal tabs in the fuser. Is the spring in the right position and are the tabs in good shape?
    Totoro
      • 37532
      Yo might have to replace the fusing unit lower case.
      • StephenB
        • Aug 2015
        • 244
        Make sure you have the correct press roller, had a 1027 (similar) do that to me last week.
