MP2851 with DF3030 skewing and jamming
  • copyaction
    • Oct 2007
    • 991
    About 1 out of 50 pages skews and jams shortly after it starts feeding, as in the picture.
    I have replaced feed rollers and belt (also swapped whole primary feed assembly)
    replaced left side cover.
    replaced black plastic guide right under where paper is stopped.
    replaced torque limiter and sep roller.
    cant see anything obviously warped or deformed to cause the skew.E74FFFDC-3D8D-4C82-B6FE-FC51721EDD05.jpg
  • jonhiker
    • 661
    Re: MP2851 with DF3030 skewing and jamming
    Try replacing the clutch.
      • 37533
      Check the skew correction roller. The idler roller might not be making proper contact at the rear.
      • copyaction
        • Oct 2007
        • 991
        thanks, I will try both of those.
        • copyaction
          • Oct 2007
          • 991
