MP C5501 tearing ITB belt along it's back edge.
I see a strip on the edge of the belt. In some places it's worn through the outer layer and started to curl.
This leads to a tear to start along that rear edge that eventually gets longer with a flap occurring.
I'm not seeing copy quality issues due to this problem but I'm going to replace the ITB as a unit instead of just the belt.
Do you think this will end the tearing problem?
This is the second time this has happened in 2 years (150k copies between issues).
Is this a known issue with these?
Thanks for looking!
Jeff in STL
Thanks for looking!
Jeff in STL
