c2003 beeping noise from black pcu drive
  • Mark Bbb
    • Jun 2012
    • 1662
    When sp5804-136 (pcu black drive) is activiated (without pcdu black in machine) it is beeping.
    The machine has 150K and is located in an office at normal conditions.
    Disasemble the drive unit (to lubricate) is not so evident at first side...
    Have you had this problem before?
    Greetings,
    Mark
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: c2003 beeping noise from black pcu drive
    As the K PCDU has a rated life of 60k, the lube bar is probably shot, replace that first. The squeak could be coming from the ITB cleaning unit.
    Hit it.
    • Zeldaman
      • Mar 2011
      • 946
      • Mark Bbb
        • Jun 2012
        • 1662
        When sp5804-136 (pcu black drive) is activiated, is ITB then turning
        • TonerMunkeh
          Professional Moron
          • 3865
          Indeed it is.
          Hit it.
            • 37448
            Are you sure that it is not an alarm signal coming from the speaker because the PCDU is not installed?
            • Mark Bbb
              • Jun 2012
              • 1662
              Slim: i used the term "beeping" because in my view "sqeaking" is a sound which is more like a continues craking noise, in fact a noise which - when it is not solved - will end up in defective parts. Beeping noise wil not end up in defective parts, although it's sound is continuesly...
              Do i make myself clear?
              So, it is not beeping like when a pcdu is not in the machine while all covers are closed and the machine is on... (because that is what you mean)
              I think it will be a lot of work to solve this.
              I understand although that you folks didn't have this problem before?
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                We are starting to get problems with the toner supply hopper making a clicking noise add toner may also show
                Regards Mark
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  There is no pcdu, fusing- or transfer unit in the machine, and when put on sp5804-136 to on it beeps...
                  even with a swapped entire drive unit and K transfer motor...
                  Could it be this toner hopper is activated when sp5804-136 is active?
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    The waste system is also run by that motor, could be one of the recycling coils is binding.
                    Hit it.
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      Yes, dear tonerMunkeh, i just figured that out myself... !
                      It took me about 12 ours to find that out !!!
                      Why isn't that mentioned in the System maintenance manual?
                      It just says: "
                      sp5804 is driving the pcdu & ITB" But did not mentioned the toner recycling system !!!!!!!
                      !!!!!!!! grrrr !
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        It just says: "
                        !!!!!!!! grrrr !
                        Sorry: not toner recycling, toner disposable system...
                        Has anyone the procedure how to replace this unit?
                        • sturmtrooper
                          Copier Combobulator
                          • May 2016
                          • 587
                          It just says: "
                          !!!!!!!! grrrr !
                          Because Ricoh.
